were is the bleeder plug for bleeding ur coolant
rear_wheel_559
were is the bleeder plug for the coolant at ?..and weres the coolant plug on the engine..?..help plz..no heat need to get bubbles out
irocknrol2
Car: 1991 240sx Hatch/1993 240sx Coupe
The bleeder screw is located on the top of the intake manifold, i believe it is an 8mm, not sure. If you dont have heat, it may not be bubbles in your system, it could be a bad thermostat. I am not sure what you mean by "coolant plug on the engine".
rear_wheel_559
then why does my car sound like its boiling or something..u can hear a boiling kinda noise from the inside of the car..outside also but not as much...dhave any idea?
blackbetty
Is your overflow box full???? Mine was boiling water when the hg was bad.
topairhead
Car: 180sx
yeah mine boils like that when its hot water coolant is runing threw the hose and up in the tank.
