96Qowner wrote:.....No after market intake has ever been shown to deliver more horsepower on the stock engine....
Only because there has never been a test showing it does or doesn't have more power. It's all opinions until someone actually does a test. My intake IS a cold air intake and takes the air by the fog light. Some will say it's not as "cold" as the OEM because it's down by the ground. It's only 12" or less lower so I'll take the "superheated" air from down there.
I made one and it works great. I made another to make my turbo work and have my original if you are interested. Doesn't work on the Active model because of some components that are mounted where the new air filter will go, not sure about the "t". It's not a simple bolt on though, you have to cut a hole under where the OEM airbox is and run the new tubing down through there. Makes air filter changing a little more difficult.
It's your call, many people are convinced that Nissan made the best intake system on the planet that can't be improved upon, I say nonsense. I'm sure you'll hear from more naysayers.
Here's a link to the thread I made about it.
zerothread?id=246554
Here's a pic of the one that I have for sale and the other pic is of the maze of plumbing you will be replacing.
