Were can i get a new hose ?
CaEric
Car: 91 Sr Pwred Coupe
Trying to figure out what hose this is ? And were i can get a new one ?
anumeric
Car: 1989 RS13, 1986 AE86 GT-S, 1948 2-Wheel Rickshaw.
Looks like the heater hose. I just remove my hardline and ran a new hose from under the intake mani to the firewall. Any autoparts place will have it. As for a pre-shaped hose "if your keeping the hardline and bracket" I couldn't tell ya.
Nunook
I second that notion
Bwana
Car: Denali
Yep, looks like heater hose. If there's enough of it there, and if you're friends with the guys at the auto parts store you can take what's left of what you have and go in the back and look through their hoses until you find one that's close enough to do the job. That's how mine's put together!
tyrannix
Car: go big or go home
your quickest fix answer is a barbed fitting and a few clamps. unscrew that shorter bottom piece and bring it with you to ensure the right suze (unless you have a caliper to measure)
but yeah, with a LHD car, you can ditch all that junk and go straight block -> firewall , firewall-> collector under plenum with any piece of straight hose
hose that came coiled when you bought it is best, it fits like it was made to go there
CJ
biosehnsucht
unless you're in RHD land, the stock heater hoses there are totally worthless. unbolt the pair of em and junk em, run hoses from the LHD passenger side (where these hoses originate) right into the heater core (also on LHD passenger side)
If you have RHD car, then heater core is on opposite side and yes you need these or to replace these..
