were can i get a IAC/aac sensor from?
POOPmouth
Car: The Devils pimp ride
i belive my IAC went out-when pluged in car will rev then die- checked maf good ecu good
- unplug the iac and car sounds good besides cutting outneed new one- cany anybody point me into the right direction-as for stores- phaze2- dont have them- supiror nissan 300 plus let em know part number
thanks
POOPmouth
bump
Carl H
take it off the manifold and remove the solenoid and adjustment screw, get some throttle body cleaner and go to town on it with a toothbrush.if the solenoid went out get one from a dohc ka, make sure to spray some light oil on the spring when you reassemble it.
POOPmouth
AWSOME- INFO kool will try out thansk
trynam4size
Car: 240sx
IAC from a 93' sentra would fit fine on an rb25det.
