wer is thermostat located???
irichjohn
Car: 1991 nissan 240sx
my engine is KA24DE,please help me to find wer thermostat located at?tnx
DALAZ_68
Car: 90' 240sx CA18det
follow the lower Large radiator hose from the bottom right of the radiator to the engine...that is connected to a rounded metal pipe looking thing with 3 bolts i believe
irichjohn
is the thermostat next to the water pump?
JeromeS13
Car: 2008 Subaru Impreza STI
Its inside what water inlet housing.... Just like ^^^ he said.
-Jerome
irichjohn
is it conected on the lower radiator hose not the top one?coz i saw online they sed its the top radiator hose conected.
DALAZ_68
nope its lower...
its connected to that inlet ( thank u for the proper term) 3 olts and its inside sitting pretty
and yes its to the left of the pump ( if u stand infront of ur engine)u see the giant hose were its connected to... u gotta remove it and its inside...**** so repetitive today...i needa stop drinking
JeromeS13
DALAZ_68 wrote:nope its lower...
Wouldn't that make it the upper hose, if its on the right side of the vehicle (always give sides of vehicle from the driver's perspective).
Make sure you bleed the HELL out of it after you change it.
-Jerome
DALAZ_68
-Jerome
both hoses ARE on the right side there bud
my engine:
see to the LEFT of the water punp in the picture... that hose...connected... thats were ull find it
ill simplify it even further
Modified by DALAZ_68 at 11:10 AM 10/12/2007
irichjohn
hey to put the new thermostat,is their any proper way i mean like w/c one suppose to be on top & w/c one is bootom coz online its says the jigle be on top but i dnt see any jigle.
DALAZ_68
brain not working elaborate...and wut is w/c
irichjohn
w/c = which.i mean for the position of thermostat,is der any propr way to put in it?
DALAZ_68
the same way u took it out...
i know theres a gasket that goes on the rim of the actual thermestat that u get when u buy one from autozone...which u dont use...cuz realize... autozone parts are for multiple uses for a buttload of different cars...
irichjohn
thanks for ur help buddy!!!
DALAZ_68
happy to assist...now i sleep
JeromeS13
Haha. My bad. Its been a while since I looked at a KA.
And, when you install it, make sure the air hole is at the top.
-Jerome
DALAZ_68
yeah that...
irichjohn
hey buddy i need help.i changed radiator,water pump,thermostat but the temp gauge still went high.i really dunnoe whats goin on now w/ my car.theirs no leak
DALAZ_68
temp sensor might be busted...
its got a red tip on it...DO NOT REMOVE WHEN CAR IS HOT!!!
either that or u might be springing a leak somewhere...
i suggest u leave ur cap off next time u start ur car ( from cold start) and watch the water... if it over flows either ur reservoir or ur radiator just keeps over flowing not bubbling and junk then either ur thermie isnt working rite...or ur pump and ahh pumpin...did u make sure to bleed the system on an incline (front going uphill)... cuz if u didnt ur leaving air pockets...which equal hot air... which equals more heat
irichjohn
U SED BLEED SYSTEM ON AN INCLINE,U MEAN THE PUMP?WE DIDNT DO THE INCLINE THING.HOW TO I TAKE OUT THE AIR POCKETS?
JeromeS13
Jack up the front of the car when you're bleeding it. And shake the hell out of the front core support.
-Jerome
DALAZ_68
u can also try pumping the top radiator hose by squezing it
