Couldn't agree with this statement anymore.nismoplsr wrote:
hopefully in the spring i will be going back with better tires an LSD and some more practice.
oh i have the .86 AR EX housing which has to do with the spool time. The .86 exhaust is shooting you in your foot with that turbo. Even with a .64 housing you will see some lag, but it will spool-up to full boost a lot faster than the .86 housing. And if you still need the transmission with the LSD, I still have it.nismoplsr wrote:well its laggier than i expected. I start seeing boost around 3k and is slow spooling up to 4.5k where i probably see about 7-8 psi then it screams to 18 psi by 5k.
i have a feeling i need to adjust the settings on the profec b. i havent gotten to play around with that since the turbo upgrade.
