Went to the track for the first time!!!
kapower06
mods: ca18det 1990 240sxhks air filter3in turbo back exhaustno catbridgestone potenza g009 tires 195/60/15's
first run ever in my life. 17.2 at 92mph no traction (didn' t do a burnout)best run was a 14.5 at 95 pulled a 2.2 60' with open diff. what do you guys think?
namwons_240
Car: 97' 200sx ser
i think 14.5 with a ca for your first time at the track is decent.
c-rad
Car: 1991 Nissan 240SX w/CA18DET
stock turbo, stock boost, side mount ic.... I'd be happy with that! Gives me hope!
Kouks
Car: 1996 Nissan 240sx S14 Sr20det
I am hoping for 14 flat on 8 lbs on Sr turbo, so thats pretty good. Get a boost controller and keep practicing!!!! good Job.
kapower06
Thanks. I do have an sr20 ARC smic. Stock turbo stock piping and a walbro pump with out an aftermarket pressure regulator(pig rich). It launched very good and pulled hard through first, then once out of the concrete launch box, I got into second and it spins for a few tenths of a second then grabs... I think if I could control it better, and turn the boost up to about 13-14 pounds I may be able to pull off a high 13, low 14. Before I go does anyone have some advice, Im going again tomorrow.
c-rad
kapower06 wrote:Thanks. I do have an sr20 ARC smic. Stock turbo stock piping and a walbro pump with out an aftermarket pressure regulator(pig rich). It launched very good and pulled hard through first, then once out of the concrete launch box, I got into second and it spins for a few tenths of a second then grabs... I think if I could control it better, and turn the boost up to about 13-14 pounds I may be able to pull off a high 13, low 14. Before I go does anyone have some advice, Im going again tomorrow.
Lower your tire pressure to about 20-22psi.
kapower06
Will that cup the tires or seperate them, they only have about 100miles or so on them? Im hoping to get around a 14.2 or a lil lower, if it doesnt rain tomorrow then Im gunna go then,. I have a manual boost controller that Ill hook up out there and put it to about 13-14 pounds and see what that does. thanks again
