NeedCAforS13 »
https://forums.nicoclub.com/needcafors13-u4234.html
Mon May 02, 2005 8:08 am
and made 178whp/ 162ft/lb
mods are:SR t25g w/ stock dump tubeARC side mount intercoolerHKS bov2.75 inch BRM downpipe2.75 inch Blitz Realize TT-R exhaust (quiet)pulsar electric fan on Koyo radiatorstock boost (8 pounds or so because of the exhaust/downpipe)
had it done on an in-ground dynojet at a local supra shop (AutoTuner)... paid $50 for 3 pulls. Did the first one on a stock ECU, second one on a tuned ECU I got from Paul (MovingViolation) but it's basically stock with no rev limiter, speed cut, or fuel cut (made 175 on those two) and the third one I put the Horsham Developments Stage 2 chipped ECU on and made 178hp. All three runs were pretty constant at 162ft/lb torque. If you calculate a 15% drivetrain loss, power at the crank is roughly 200-205hp. Almost dead on with a stock s13 SR (see use a stock s13 SR turbo, get stock s13 SR numbers, on stock boost). I'd like to do another run in a while with higher boost once I get my skyline intercooler installed.
I am quite happy with my stock boost numbers and my a/f ratio looks nice and solid too. All in all, good numbers for 8 psi
dyno pictures
dyno sheet
Sean
