WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Fri Apr 30, 2010 6:52 am
More slipping of the clutch is required to get your 60' time down. I rev to about 5k and slip the clutch out. I don't "leap" off the the line like some, but I am able to control wheel spin a lot more. This is especially important to people with a smallish turbo since you're in boost almost immediately. I've always had a turbo that is considered to big by most, so the slip creates lots of load on the motor which creates boost relatively quickly without having to rev the piss out of it and drop the clutch.
If you're dropping the clutch you'll definitely get wheel hop and spin. I used to practice launching on the street all the time until I knew what was the best rpm/slip combo that let whatever tires I had at the time to keep the most traction.
Also, I'm pretty sure the 240 picks up speed at the top end because of the gear ratio's. 1st and 2nd are short gears so you're shifting quickly, where 3rd and 4th are longer.
I can't believe you popped your damn motor so quickly Chris, have you thought about just popping the pan off and swapping in a used stock rod/piston combo? When I was on Okinawa I used to pop the #5 and #6 pistons in my RB. I got tired of swapping motors all the time, so I would just drop the pan, pull the head, remove the cracked slug, use a cylinder hone on a drill with some WD40 and run it in/out of the cylinder for like 5 minutes, install a used rod/piston combo and put everything back together. Sometimes that cylinder will be down on compression, but nothing like running with a cracked ring land.
