Remove the oil pressure sensor and connect a line to a hand pump that can draw motor oil from a can. With the hand pump all the oil galleries and the oil pump will get pre-oiled.5upra wrote:sorry its been awhile, but I put some assembly lube on the gear set and regulator so I wouldn't think its stuck...I have run the battery down to almost nothing with dry cranks even tried the compressor thing......still nothing. I would think if I dropped the oil pan I could shoot some vasoline up the pick up...do you think that would help at all?
I actually heard of this one guy in Hickory that used that when he assembled his motor. Maybe that's why his motors are always runny crappy. Another bad thing about it is that the guy never admits defeat. Always whining and giving lame excuses when his car or his buddy's car loses in a race.5upra wrote:Its only for the oil pump(motor oil would just run out)...not to assemble the engine with.
yeah...don't follow his foot steps.NCturbo75 wrote:I actually heard of this one guy in Hickory that used that when he assembled his motor. Maybe that's why his motors are always runny crappy. Another bad thing about it is that the guy never admits defeat. Always whining and giving lame excuses when his car or his buddy's car loses in a race.
hahhaha...trust me, I most certainly won't. I don't really like the guy anways. He is just a retard who loves to talk shiet.5upra wrote: yeah...don't follow his foot steps.
I was thinking the oil pan too.exode wrote:The biggest problem is the oil pan. One small dent right in the center made it so my motor got ZERO oil pressure. Make sure the pickup is clean, and just keep doing dry cranks until you see that light go off.
Another trick is to clamp off your valve cover breather lines and have someone stick an air compressor in the dipstick tube while you crank the motor over. These oil pumps get frozen all the time, rarely do they go bad. Just fiddle around with it =)
