Jeff Williams »
https://forums.nicoclub.com/jeff-williams-u431.html
Sun Aug 07, 2005 3:43 am
With some good wrenches, the upper links can be replaced in about 45 minutes. The VC gaskets took me aobut 4 hours. A MC replacement should take about 2 hours.
I would be very careful taking the Q to anybody not familiar with the car, unless you fully trust them.
I would think the place you ahd your Volvo worked on might be qualified. Start calling the local shops or used car dealers that have shops, to see if they have any ex-infiniti techs working for them.
Most of these shops charge about $65 to $75 per hour.
If you ahve some vibration in your brakes, then the rotors need turning or replacing. They can be turned about 3 times, before they need to be replaced. It takes about 1 hour to R&R the brake rotors.
I have spent nearly $5k on Lola getting her "Up-to-spec", and she was fine when I bought her, just a little neglected. Tony did great maintenance, but just didn't want to spend the next $10K necessary to get her perfect at the dealership pricing level.
