Went parking, Car went DEAD!
simple240
Car: '91 240 hatch
My son went parking in his 1991 240sx shut off every thing was fine, got ready to leave and when he turned the key to start it, nothing, and I do mean nothing happened. It will not turn over, no lights on the dash when key is turned on, nothing. It's like there's no battery on the car but hte battery test 12.56 volts with meter the cables are clean and tight. I am at a loss. Can someone point me in the right direction? I drive an older jeep and am not familar with these cars. TIA.
vancouverbc
Car: 1991 240sx
I would check the fuses in the fuse block and in the relay box.
JNM240
Car: 90 Coupe, 90 Hatch (CA18DET)
And make sure both battery cables are firmly attached.
RB280SX
JNM240 wrote:And make sure both battery cables are firmly attached.
And there also might some slight corrosion affecting the area of contact between the cables and battery.
ACESXX
--> "ALT" fuse in the box on top of the battery it should be a 70a or 75a fuse if its blown replace it! its bout 12 bucks @ dealership!
ricebike
2002 Quest
2005 Altima
can be the battery itself; i had similar problem & when I load-tested the battery off the car/ it was bad...
u try to jump start it yet?
benemorius
Car: s13, s13, eg, e36
Play with the battery terminals. They won't get a good connection if they're not clean and tight.
