went over a bump, heard a clank, now revs lower?
NissanSupraGTR
Car: 1990 240sx SE hatchback
just as the title says, that's what happened pulled over to check the exhaust but everything looked fine. noticed a slight whistling noise but dont know if that was there before. any idea as to what happend? installed a new intake sys. recently as wel. before intake revved round 800, afterwards 900, after bump 700 or a little less.
180fan
Car: 89 fastback
mmm...well probably the most important part is to check over the oil pan for dents...
NissanSupraGTR
the oil pan's fine, im also hearing feint pops while i idle, and a few more while im in the higher rpms...
NissanSupraGTR
k i got an update - seems it only happens when the engine warms up, or when ive been usin it for a while - this morning it started up fine and idled normally, but stuck in traffic a couple miles away it idled lower. its gotta be exhaust right?
NissanSupraGTR
No one can help? I have no idea whats going on. Here's a list of what's happening:after driving around and warming the engine up there's1. a loss of power/torque (car feels slower accelerating)2. a decrease in the sound of the exhaust3. A decrease in rpms while idling (900 cold start to 700 warmed up)
I checked all the linkages in the exhast and they all seem fine, except for the one that connects to the engine block (the part of the manifold that goes to the last two cylinders is only connected by one bolt). I also recently replaced the oxygen sensor, could it be that i didnt tighten it enough? pls this is really bugging me and i just want to get my car back in good shape
Chukidori
Im having a similar problem.
Im going to check Maf and TPS tomarrow....perhaps you should try that in the meantime.
NissanSupraGTR
Whats the tps?
ZiG
Car: 1993 240sx coupe
throttle position sensor.
You might have smacked something on the exhaust and loosened it or something. I'd just check all the connections and make sure they are nice and tight. Can you tell where the whistling noise is coming from?
driftneil
Car: A pile of cars.
The car is supposed to idle at round 700, the intake shouldn't change the idle.
NissanSupraGTR
idk whats happening, all i know is that it starts of idling around 900, then warms off and gradually drops down to 700 warmed up. this isn't normal right?
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
When the motor is cold, the idle speed is around 1000 RPM. After it's fully warmed up, the idle speed drops down to around 700 which is normal.
DirftKing102
Car: Nissan 240sx 1993 convertable
at least you didnt go over one of those parking bumps where you park your car and there is a bump like 5-6ft. My car is fine though, i am amazed. These 240sx's can handle so much.
NissanSupraGTR
rogoman wrote:When the motor is cold, the idle speed is around 1000 RPM. After it's fully warmed up, the idle speed drops down to around 700 which is normal.
maybe i didnt notice it before? who knows. the car runs, and i guess that's all that matters :/
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
Vacuum leak...
driftneil
Yeah man totally normal when cold.
