Went out to the track tonight...
spanishricer
Car: '95 240SX & '03 M45
Well I wanted to head out to the 1/4 mile track this weekend, but they weren't open for public racing...so I drove 15 min to the local 1/8 mile track and paid $10 for Test N Tune night.
Not what I expected to run...but then again, I didn't really know what to expect
Best run was a 8.9 @ 79mph. I was struggling for traction (lack of track prep) and best 60ft I could manage all night was a 2.15
Did beat a Z28 and a Ford Lightning while I was there though
Here's my best timeslip of the night...
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
So what do you think you will run at the 1/4mile track?Was the z28 a LT-1 or LS1?
GhostDriver
Car: 1991 Nissan 240SX RMS13
NIce...that 60' is pretty good. I'd say approximately low 13s(+, -) in the 1/4. Did you decrease the tire pressure in the rear?
spanishricer
It was an LS1 Z28
And I didn't play with the tire pressure at all. Still running the recommended 40psi.
Hopefully next time we'll go as a group. I'll probably gut the car from the rear seats back and play with the tire pressure. Take vids too
GhostDriver
Do get it on film. That'd be great. About the Z28....how about an LS1 or LS6 in an s-chassis instead(?) because solid axles suck.lol j/kI love F-body SS Camaro.
9240sx
Thats a fast 240,I raced my friend with a 01 Trans Am with a SLP intake,and at the top of 3rd he had me by maybe 2 cars
TurboSilvia7587
so what is done to ur 240?
spanishricer
TurboSilvia7587 wrote:so what is done to ur 240?
Motor: S14 SR with all the basic upgrades running 12lbs of boost.
Drivetrain: ACT clutch kit, Mine's short shifter, S15 HLSD
Suspension: stock
TurboSilvia7587
how do u like that mine's short shifter?
spanishricer
TurboSilvia7587 wrote:how do u like that mine's short shifter?
Very nice short shifter. I've been missing the feel of my Prelude shifter ever since I got the 240. But now they feel very similar. Short, precise throws and a rock solid feel.
Mixmastamunkh
Car: nissan 240sx
well, i have a couple things to say. 1. im a huge s13 240sx fan, but an overal 240 so rock on with the SR'd 240. i'd be happy with such a fast car. (im gonna CA mine to get it around there, but hopefully a bit faster) 2. I'm not a honda hater unlike some of the people on these forums, and i particularly like the prelude, and lemme tell you, that is one SWEET lookin' prelude you had back then. -overall impressive, keep it up (and good luck with that suspension.)
spanishricer
Thanks for all the kind words.
The Prelude was a great car. I learned real quick that it was really going to take some big money to make it a fast car in the straights, so I focused mostly on making it a canyon carver.
Now that I have the 240, I have some of that pure, brute force that I was missing in the 'lude Hopefully I'll have my suspension together within the next 3-4 weeks, depending on how long it takes SPL to get my parts together
cdlong
Car: '95 240sx
spanishricer wrote:Still running the recommended 40psi.
since when was 40 psi recommended? check your door pillar, not the tire.
spanishricer
Well there's nothing in my doorjamb/pillar the states a recommended tire pressure. The tire states a max of 45 psi, so I was told 40psi would be a good pressure, since lower pressures would accelerate tire wear. Seeing that I drive close to 100 miles back and forth to work daily, I chose to run the above tire pressure.
cdlong
Car: '95 240sx
too high pressures will wear out your tires faster in the middle. i think the recommended pressure is 32 psi, but if you want to run 40, you are more than welcome to.
Mixmastamunkh
Car: nissan 240sx
it says the reccomended psi on the tires themselves alot of the time...
Veriest1
Car: '96 BMW M3
'93 Nissan 240SX coupe dd
As long as your tires are wearing correctly then there's not problem. I ran 40 in Kumho Ecstas on my Z3 for years. The higher pressures will give a lot less sidewall flex but they'll be a little bouncier.
cdlong
Car: '95 240sx
Mixmastamunkh wrote:it says the reccomended psi on the tires themselves alot of the time...
that's the max pressure for that tire, not what's recommended for the car.
Mixmastamunkh
Car: nissan 240sx
well than go a little lower and you're set. try 35, that should be practicle and confortable.
TheOne
Car: 93 240sx FB
i think its 32psi normal, pretty sure thats what they use @ a toyota dealer(my brother works there, he owns a S14 though,lol)
