ride4lame wrote:yeah reliablity and safety when you increase the boost or put on a bigger turbo is lame
I'll be using the AEM EMS for reliability and safety when upping the boost. Eventually, I'll probably go with an air to water setup and run ~1-1.5bar through a sidemount, depending on the efficiency of the setup.
When my wastegate was broken, coming home from the desert, I did lots of sustained 4500-5000 RPM driving with as many bursts of 14psi as I could get out of the car without hitting the limiter. The EGTs never went over 1450. That's in 100 degree ambient temps.
One day, I'll eventually get a FMIC. That'll be the day that the car comes off of the street.
