ceniack »
https://forums.nicoclub.com/ceniack-u14675.html
Fri Jun 17, 2005 12:14 pm
went to firestone to cash in some more on my lifetime alignment with the hach.
front left
camber: -2.4 spec is -1.5-0 caster: in spec toe: -.30 spec is .02-.11 SAI: 14.0 spec is 12.5-14.0
front right camber: -.8 caster 7.6 toe -11 SAI: 14.2
rear toe and camber is also way out of spec, but that could be because i had a rear diff and drive shaft that i forgot to take out before i went in to get this done.
and is this really that bad, the car seems to drive straight with no apparent handling problems.
what all can i do to get this stuff in spec, they said they couldnt' see any control arms bent and also said they couldn't get enough adjustment out of the stuff there to get anything in spec. suggestions would be greatly appriciated.
also, i am not sure what SAI is so could someone enlighten me.
