Gregariousgreg »
https://forums.nicoclub.com/gregariousgreg-u5665.html
Mon Apr 14, 2003 3:47 am
Are all your spark plugs plugged in? My 240 is currently running on 3 cylinders do to problems with the valves, and my dad's C-cab broke a rocker arm and was running on 7 cylinders for a day but jeez, one cylinder. That's a new one to me.
Need more info. Try pulling out all your spark plugs. Check to see if any of them are badly damaged or have a profuse amount of oil on them. The plugs can tell you a lot about engine problems. Also compression check it. That's all I can think of to do with the info you've given.
Actually, better yet, take it to a mechanic. It seems like you don't know a whole lot about your car. I could be wrong, just try to be more specific.
