ArmedAviator »
https://forums.nicoclub.com/armedaviator-u262955.html
Tue Apr 26, 2016 10:29 am
I took both rears apart again to try to figure it out. I also ran a few trials/tests.
I believe that the original issue was caused by the insertion of the rubber gasketted slide pin had caught it and cut it causing the original deformation. This deformation cause the slide pin to stick just right but it would only be noticeable with the slide pin tightened down in the caliper. At that point, I would have noticed it if I had tried to spin the rotor.
This morning I had cleaned out the channels better than the side-of-the-road-repair. I had gotten a bit more rubber gunk out of the bottom of that channel. I re-assembled the brake WITHOUT LUBE (as a test) and it worked fine. No more sticking and the brake worked when the pedal was depressed and released correctly when pedal is let up.
The wear pattern makes sense for this scenario, too. The upper, and inner corner of the outer pad had significant wear. If that pin was not able to slide all the way in, the caliper would be forced to put pressure on that corner of the outer pad. The inner pad has a little wear, also uneven, but not nearly as bad as the outer.
Since the intense heat could have damaged the piston seal in the caliper, and who knows what else, I opted to replace the whole caliper (including slide pins, boots, gaskets, bracket). I tested the function of the hose and it seems fine. To order it through Rock Auto, it would have cost 3x as much to ship it next day than the cost of the hose. I also ordered new pad mounting hardware for both rears, new boots and gasket for the right rear, and new boots and gaskets for both fronts. I'm also going to switch to a different grease as online reading points to the Permatex green bottle that I've used causes rubber to swell. I'll find some silicone brake grease. Of course a new rotor and pads are also on their way as well.
The parts arrive Thursday and I will have that evening to try my best to fix it. Here's hoping it works out. I won't be able to test it until Friday evening when I'll be able to have a friend help bleed the caliper and follow behind me incase of more issues on the test drive.
I also hope the wheel bearing continues to hold up after being heated so much. The paint on the brake cover behind the rotor bubbled up and flaked off.
