well finally start to get going on the project. friend is doing a motor swap on his 300zx so he gave me his NA motor and going to do some work to it before i drop it in. just going to save up a lot of pics and post them all up at the same time.
Here is what I'm doing to the J: tearing motor down, cleaning entire block/painting, pulling pan, find out grade for rod bearings, buy rod bearings, replace rod bearings, shim oil pump pressure relief valve, replace all the oil seals, paint exhaust, mod exhaust valve covers to delete pcv system, finish modding intake plenum and get it powdercoated, gonna need new silicone hoses for the 60mm tb, wire tuck coil pack and injector harness, swap motor mounts, swap on j30 exhaust, swap on j30 oil pick up and pan, install new style cas, clean timing belt covers and paint, install all my lightweight pulleys, clean transmission and paint silver, repaint engine bay while motor is out, reroute some electrical stuff, drop motor and trans in and get it running. then comes suspension by replacing my front wheel hubs, front coilover inserts and put in stiffer spring rates. 2 or 3 wheels need to be fixed cause they are bent and need to go back inside the diff and reset it.
also got the AC low pressure line out of my friends 300zx and need to get the J30 end welded on to mount it. pretty much instead of the thick AC line running behind the motor and next to the drivers side exhaust, this will run on the passenger side frame rail and go in front of the motor along the sway bar. looking for better clearance around the motor.
made this small enclosure for the motors. i still need to get my J30 towed home and pull its motor.
