stock L24 will rev to 8k, been there done thatInsanityInc wrote:You can build a full race N/A L24 that will easily get to 300whp. The thing can rev much higher than a KA.
EDIT: bore is 83mm, stroke is 73mm. The engine has awesome potential. The limiting factor for RPMs is the head. just do some valvetrain work, put on better carbs, and it should be able to make peak power much, much higher.
