roe_wedge wrote:ahh...if i do this swap i realize i will have to put in a new gauge cluster... what about importintelligence.com? is it just faces or is it the gauge cluster? Can it work? it seems good for a cheap price!
You won't need a new cluster if you have a KA-DE. If you have KA-E (I did) you just need a tachometer from either a KA-DE, SR Silvia, or CA Silvia. I got a front clip, so the cluster came with it. All I did was just stick the CA (goes to 9K RPM instead of 8K RMP BTW) in the KA-E cluster. Works like a champ.
I think the stuff from import intellegence requires your current cluster. If you've got a KA-E, you'll still need to find another tach.
