Well, FINALLY out of the NRRB Club
Nesquick
Car: Rb26 Kouki Silvia
well guys, its been a LONG 3-year build, working s*** low paying jobs, university, and spending most of money on booze lol, but finally got it running tonite :)
Heres my spec list:
R33 RB26DETT swap bored 20 over
GT3582R turbo
Stock injectors
Tomei Cam Gears
Greddy FMIC w/ custom 3" hard pipe
Tein Coilovers & Struts
Nismo Thermostat
AEM EMS series 2
Defi Gauges + Defi-Con (Oil Temp, Water Temp, Boost, Oil Press.)
Profec B 2 Boost Controller
12000K HID Kit
Greddy Timing Belt.
Aftermarket steering wheel (came with car so ???)
KTS 7 point roll cage
NGK Iriduim Spark Plugs
Flex-a-Lite Dual 12" fans - 2500cfm
GTR brakes with Sloted rotors
Custom made down pipe with exhaust cut-out
there is much more, but too lazy to type it lol
here are some before and after pictures.
Before:
After:
the wiring has been cleaned up alot, older pic
Thanks for all the help from you guys (and gals) on here :)
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Congratulations! :biggrin:
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
Hecks yea! Congrats!
Nesquick
i decided to write the upgrades lol.
R33 Rb26 bored 20 over
CP forged pistons
Eagle Forged Rods
ARP Head Studs
ACL Race Bearings (Rod and Main)
Block was acid dipped and etc etc
Head had 5-angle valve job
Brian Crower SS Valves
Stock springs / cams (upgrade asap)
Custom Made 6-1 exhaust manifold with dump
GT3582R DBB Turbo (Thanks Ricky!! ;))
AEM Series 2 EMS
AEM swapped CAS disc
Tomei Cam Gears
GM 3 bar map sensor
HICAS lock-out bar ;)
Innovate LC-1 Wideband
OEM CF Hood
SPEC Steel Flywheel
Tial 44mm wastegate MV-S
Greddy Extreme Timing Belt
Walbro 255 fuel pump
N1 oil pump
Dakota Digital Tach Converter
Other non-really important things.
Here is a pic of my receipts haha
whoareu
Car: 1993 rb25det s2 240sx vert
awesome job. man im actually about to do alot of the same stuff. im pretty sure the rings are fried in cylinder 2. so im taking on a rebuild. if you wouldnt mind id like a rough idea of how much your head work was and block work as well.
gmac708
Car: :o)
1970 Datsun 240Z
1972 Datsun 510
:woot: congratulations! :mike
Nesquick
the head that first came with the engine was full of detonation from when i ran it untuned lol.
i got amazing deals on the block work (300 bucks)
and the head 400 for a new one
