Wow! They gave you and actual rim and tire?? Mine just came with a doughnut type spare tire!! I think.... I do remember it was never used though.The driver seat moving should be repaired under warranty. There have been many members here alone that have complained of this and had it repaired under warranty. There is a TSB from Infiniti on this issue.jeostang wrote:I got one with 55k, black on black, advanced tech with Rear DVD. For 18500 (and they backdated the sale to 2008).
It was missing the spare, I told them to replace it. I could not understand why they were giving me trouble about the spare. They just didn't want to. Well they finally did (they had to order it from Infiniti). To my surprise it was a real rim with new tire. I figured it would just be full size steel rim.
Needless to say the Wife and I are both happy. Only issue so far is the driver seat moves when braking.
Doesn't really mean it is for an AWD model. You can use a spare tire that is a doughnut type for the AWD M35/M45. The only thing that needs to be the same as the regular tires/ wheels on the car is the overall outside diameter of the tire being used as the spare. Most all vehicles now come with a matching sized outside diameter spare tire, be it a doughnut or full size.rgb129 wrote:Full size spare means it must be from the AWD m35x. You need to keep the sizes all the same for that system to work right.
You still haven't told us what year it is and if it is a sport packaged model or base model. Oh, by the way, base models doesn't mean it came "without features". It just means it came with the 18" wheels and no RAS (Rear Active Steer) system. If you your M35x has the 19" wheels and the blacked out head lamps it is a sport model.jeostang wrote:We got her an M35x. Fully loaded
I was thinking about taking the spare out and replace it with a donut, to save weight (better gas mileage), is that not a good ideal since it could affect the AWD? If she did ever have a blow out, at least she could make it home, I would then put the full size back on.
As far as I know, only the Sport models came with 19" wheels (from the factory that is). Has this changed?jeostang wrote:Sorry about that.
is a 06 M35x base.
I didn't know the M35x came with 19s.
Yeah, the heck w/the glamor shots of the machine, I'd like to see some pix of the wife...tytamto wrote:Where are the pictures of the new car? Wife and the car?
