It's important to look at duty cycle when comparing welders. The cheap ones have low duty cycles, meaning that they can only operate maybe 30% of the time to avoid overheating. Also, cheaper ones use less current and can't be used on thicker metals. Bigger ones, on the other hand, often use more current (and more voltage) than what's available in many homes. Know your limits or you'll be blowing circuit breakers repeatedly. If you just want to experiment and give welding a try on sheet steel, nothing wrong with going with a cheaper model. MIG/TIG welders (metal/tungsten-inert gas) are all but mandatory for welding aluminum, but arc welders are usually ok for steel. MIG welders cost more to operate because they provide a constant flow of compressed gas around the weld tip and work area. The inert gas keeps air and moisture out of the weld while it solidifies, which is very important for aluminum and alloys. If moisture gets in the weld, the metal will oxidize and the weld will be much weaker.I haven't looked at their welders, but I buy a lot of tools from this place:
http://www.thetoolwarehouse.net
