Welding the Diff
Glimmerman
Car: 1991 Nissan 240sx with a Skyline rb20 swap
Hey,I have a problem. I have a drift comp that I will be in this summer and i still have the stock open dif in my 91 s13 240sx. I need suspension work done(coilovers) before i can do an LSD and the coilovers are going to be expensive, as most are, and I will not have enough cash for a LSD before. I have heard about welding diffs for drifting, but what I heard is that it is pretty ghetto and causes "hopping" around corners when not drifting. Any Advice????? thanks
Miller White
Car: 1989 240sx
find a 300zx dif and j30 axels.
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
The welded spiders certainly is ghetto and is unsafe on the street because of the hopping.
leezy240sx
Miller White wrote:find a 300zx dif and j30 axels.
what year 300z? cuz i saw a 91 at a jumk yard
Miller White
Car: 1989 240sx
its gotta be the newer 300's
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
Look for a ’90-96 300ZX N/A.
First thing, DO NOT get the twin turbo diff, it's got a different gear ratio in it and it will really slow your car down (3.86). The NON turbo has the same ratio as the 240 (4.06). The 300ZX uses the 2 bolt rear cover so if you own an S13 you'll need to switch it. The biggest problem with the 300ZX is that the output flanges are different. They look like a '5 star' flange where the 240SX uses 3 sets of 2.
listed here are some R200V VLSDs that will work:
Infiniti J30 95+ , No mods needed, but might need driveshaft that's used because of ABS sensor Infiniti J30 pre 95 , Needs new output flanges Infiniti M30 , No mods Infiniti Q45 , No mods
leonelrr
Car: s13,s14, z32TT, YZF R6 None of them work nothing to brag about
Just making a correction here, in my experience LSD from the Infinity q45, have the same axle bolt pattern as the 300zx Twin Turbo. Very beefy, good if you're running a torqui RB. But not recommended for stock or Sr20. Very low gearing, and you need lots of ponies to get a good launch.
So to make the Q45 LSD work on the 240sx, you need the axles as well. And you need to switch your cover, if you're swaping it on a S13. 97-98 kouki have the same cover. But you need a passengers side axle from the Q45 and drivers side axle from the 300zx TT. To make them work, also take into account the extra length due to the ABS sensor. You might also need a abs drive shaft.
90-94 J30 LSD >> 89-94 240sx you need LSD,AXLES,BOLTS, BUSHINGS, SWITCH DIFF COVER.
5-94 to 96 J30>> 89-94 240sx ONLY LSD, BUSHINGS, AND DIFF BOLTS. SWITCH DIFF COVER. YOU DO NOT NEED AXLES.
5-94 to 96 J30>>> 97-98 240sx kouki. LSD, BUSHINGS, BOLTS, YOU DO NOT NEED TO SWITCH YOUR DIFF COVER. Koukis come with 2 bolts on the cover like the j30s.
That's my experience, i don't know if zenkis come with 2 bolts like the koukis or 4 like the pig nose and chukis.
leezy240sx
is not a tt,i got it at the house right now,waiting on a good day,im gone both it up and see what problem im gone come across.
thx you guyz
Vaikis_
Car: Nissan 200 sx
you can weld if don't have enough money for 2 wayl LSD. Rear tyres just make starnge noise when conering
rb25drag
Car: 1990 Nissan 240SX 5.3 Chevy + 60mm turbo + blow threw carb.
I have never experienced Wheel Hoping with my welded diff, I have run it for 3 years now with No problems.
The rear end is going to be a personal opinion, Everyone here is going to tell you something diff, But you just need to experience them both to really know what you like. Weld is Free!!! Why not try it first?
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
leonelrr wrote: Just making a correction here, in my experience LSD from the Infinity q45, have the same axle bolt pattern as the 300zx Twin Turbo. Very beefy, good if you're running a torqui RB. But not recommended for stock or Sr20. Very low gearing, and you need lots of ponies to get a good launch.
Thanks for the update on the Q45. Never actually did a Q45 install into an S13 but good info if I ever do one.
Ericb
Car: '91 Nissan 240SX
I dont suggest the Welded Diff, the 240 I just picked up has a welded diff and it sucks during normal driving. ive owned the car for a week and already had 3 friends tell me my car bounces aroung corners. the inner wheel jumps up and down off the ground and its really annoying.
the owner before me had no idea what was up with it and told me its always had a wheel hop problem while cornering. first time i drove it i realized it had a welded diff.
4wheeldrifts13
Car: 89' RHD Nissan S13.5
Welded diffs are hit or miss. Get a good welder to weld the spider gears and make sure you seal it good w/ the OEM paper gasket or a bunch of gasket maker. and fill it w/ 80w90w. Dont forget this step: Check for leaks. my last welded diff locked on me due to a leak I didn't know existed until I heard squeaks and sudden lock-age. My opinion. welded diff is the poor man's 2-way. but it will make daily driving suck. and use common sense when driving in rain.. don't down shift into a turn while going on an offramp. Ive been to 8 events w/ welded and 1 w/ vlsd. I dont like the vlsd because it will unlock when you dont want it to (when you ease off the throttle to weight transfer)good luck man
SlipnSliden 240
Dont waste your time with a vlsd. I would weld it after coilovers. I love my welded diff, never had an issue with it. But it takes good susp to control it. If you have weak sauce factory spring rates and im gonna guess blown struts, it will wheel hop like a mofo.
4wheeldrifts13
I was going to say the exact words "don't waste your time w/ a vlsd" but I know there are people who will disagree.. In the rain I liked the vlsd..but thats about it. during the dry it was unpredictable. I really like the welded, but if you dont know how to drive it will be very dangerous come wet roads..
datsun2401972
Car: 90 Nissan 240SX XE coupe
aahhhh come on, buy a quaife atb and grip it up!
