Welding An Internal Wastegate
98240
I took the internal wastegae off and I had a grounding wire holding the flap shut. Well yesterday while I was fixing the exernal wastegate I figured I would go ahead and fix my internal wastegate flap also. So I punched it out and welded the hole that the flap was retained in. Is there anywhere else you have to weld? Since I have done this I have been unable to boost. Well I do but I see full boost around 6500rpm. I checked for boost leaks and there werent any so I am guessing there is something else inside the turbo that needs to be welded. Thanks
98240
Man I am dumb. Of course thier is another peice that needs welded it is where the flap inside use to be.ahhhh Could I just use steel or would it be better to use cast iron?
WDRacing
You can use steal, just be sure to get real good penetration. LMAO...atleast you answered your own question.
WD
Edub1
Car: 89 240sx KA-T
Too late now but why not run both WGs? That way you have a backup if one fails and more flow too.
I have an internal and I'm considering adding an external as a secondary.
SPIRONIUM
Car: 240RS group 2
hm i guess you could run two wastegates, why not? although i do like the theory of less moving parts = less chance **** gets ****ed up
Edub1
Car: 89 240sx KA-T
LOL, I have the same philosophy but one would act as a backup so you chance of failure would go way down.
98240
Thanks for the input guys. I welded the hole closed and now I am boosting again with no problem
kornaz
Car: 95 240sx SE.
Edub1 wrote:I have an internal and I'm considering adding an external as a secondary.
I was just thinking the same thing.
