welded lsd
finedtuned240sx
i was reading another nissan forum and someone welded a differential. Does anyone know anything about this, what to where do you need to weld and if this is worth it. I need opinions. thanks guys
ILikeMy240sx
Car: SR Power
People do it.. Sucks for daily driving (when turning two wheels spin at different speed) but good for drag if that's your main purpose.
dickie
Car: Killer Turtle
not worth it unless youre only going in a straight line 100% of the time. go to howstuffworks and see how a differential works, then answer your own question.
KDashy
Car: '97 Nissan 240SX
I can just imagine making left and right turns and u-turns. Ouch for the tires.
crzycav86
Car: 93 Nissan 240SX KAT
If you're seriously into drifting, a welded differential will be the best bang-for-the -buck mod you can do. But it will reduce daily driveability quite a bit because you lose a tight turning radius when going through parking lots(you understeer), and you wear your tires quicker.
If I was a big drifter, I would do it. I'd rather weld my diff for free than pay $800+ for a clutch type lsd, which is nearly the same thing.
It's all up to you. There are serious benefits, but also serious drawbacks. For what it's worth, the serious houston drifters all have welded differentials.
sleepyRPS13
Car: to sleep
welding lsd is like on impossible level.
Tartan
Car: 89 240sx
I just installed a welded diff into my friends 95 240sx w/sr20det and think he picked up almost a whole second in the quarter mile, with better driving. Car is kinda jumpy around corners, but it definitely feels alot faster than before. The sides of the tires are getting chewed up. We put it in for the weekend at the track but he hasnt called me yet to put the open diff back in. Must really like it.
getnrowdy23
Car: '95 sr20det 240sx se/2004 suzuki sv650s
no i havent called tartan up to take out the diff. yet. i kinda like it. it is rough on the car, but i like the way it performs. it does sucks trying to make tight turns though.
Modified by getnrowdy23 at 3:27 PM 11/8/2005
Chezedik
Car: 1991 Nissan 240sx
Anyone concerned with what happens when the welds break?
getnrowdy23
yeah, definately. i have been wondering about that since install. there are many things that could happen when it breaks. from locking up the rear end to being a normal open diff. haha
Chezedik
I would be surprised if a bit of weld didn't jamb it up and cause a kaboom, and probably it locking up. And what about the trans?
Juujai
it's fine but you'll end up spending more money on the tires int he long run rather than just getting a real metal clutch diff.
