raging panda »
https://forums.nicoclub.com/raging-panda-u4045.html
Wed Jun 15, 2005 7:55 am
I have been running a welded for a few months now, yes you get wheels hop on slower turns, because instead of the diff slipping, something has to give, and it becomes your tires, so they make a chirping noise around small corners. It also creates a ton of understeer in turns, but so does a 2 way because it locks under decel, and accel, but the welded probably even more. It isn't ideal for auto x, track racing, or anything like that, I would go with a helical or something of that sort if I were to create a track car, and I still might someday, but for now, I am into drifting since it is the cheapest way to get onto the track and be competative right away, provided you have skill.
welded does have wheel hop on slow turns, eats tires, although if you drift, it you wont really notice eh? It can be dangerous, but only when you drive like an ***, I've only had problems once, it was wet and I was late for something, dont remember now. Otherwise, ive never ever drifted on accident, just dont be stupid. As for snapping axles, I have heard of it but never from a primary source (on S chassis), havent experienced it, so I keep a spare at home just in case, but I dunno, maybe if you are using like a 255 tire, but with 195s im using or like a 215 i know a lot of guys of 17s use, i havent heard anything from them. I suggest it if you are really into drifting, if not, buy a vlsd or something, if you have money i would definately recommend a real LSD.
