welded differential to limited slip?
PSherg
Car: 1991 240sx SE (coupe)
I may consider trading my s13 for an s14 with a welded diff.
I HATE welded diffs; but how hard would it be to remove the welded diff, and replace with a limited slip? What will be needed, etc;
Hijacker
Car: '92 240sx Convertible
'94 F-150
If the diffs stay in their pumpkins, all you'd need is the proper output shafts for the LSD and the proper cover (S13s are 4 stud S14s are 2 stud)
