RustspecS13 »
https://forums.nicoclub.com/rustspecs13-u75597.html
Tue Jan 06, 2009 5:38 pm
VLSD- blows. They can work "OK" for a little while but they have to slip first then the heat and fluid movement inside the actual diff starts to lock it. But it only provides limited locking power, and when they get really hot they stop working. Like on a low power car after autoxing or drifting, and then it unlocks on you when your going 3rd gear around a bank, thats really bad.
So VLSD is a temporary locking setup AKA horrible.
Welded- My friends run these and have no problems what so ever. Here in ohio theres alot of drift cars running around and I know most of them. Its probably 50/50 welded and clutch type in the cars, and theres no problem what so ever.
Ive personally driven my friends s13 in every weather possible with a welded diff and theres NO PROBLEM what so ever. If you have bald tires yea your going to have problems. But any car will. It requires only a minute amount of brain power to safely drive a welded diff car in the rain as long as you dont do retarded speeds around corners. WOW big shocker there. And as far as street tire wear, it depends on how you drive. One of my friends it was a problem, and my other friend didnt have a problem at all. It depends.
Summary- If some one competent welds your diff, then its durable, and they are completely predictable since they are 100% lock 100% of the time. The only comprimise is tire wear, and thats not even all too bad. Its a GREAT temporary setup if your saving for a 2 way.
2way/1.5way/clutch type- What I run and I LOVE IT. I daily my car and my diff has 25K miles on it or so and about 30 drift events and pratices and 5 autocrosses. Locks perfectly every time and I change the fluid every 5-7K miles. I should probably change it more often. Yea it clunks but thats the price you pay to not wear your street tires out, and still have perfect full lock when you need it. Who ever said you need to rebuild it every 6 months, ignore them they are doing alot of things wrong.
Summary clutch type is more expensive but durable, streetable and trackable all at the same time.
I personally drifted for two years semi-seriously (I was poor so i didnt get to drive in too many events) then I bought a 100mile old KAZZ 2 way and it rocks, and since then ive driven several welded diff cars on track and on the street, and one VLSD car on track and street. Dont waste your time on VLSD, and get a welded diff asap, and then save for a Clutch type. I really wasted 2 years worth of drifting with an open diff, and I wish I would have gotten a welded diff but people told me its dangerous and all that but its not at all.
~Alex
