welded diff
on4now4
hi everyone im fairly new here but i am looking at buying a 1991 240sx and the only thing that im worried about is the fact that it has a welded diff from what i have found it will cost alot to get a new diff installed and it would not be easy to do myself. so i am wondering if i drive it as an everyday car can having a welded diff break anything or cause any probs.
maik21
Car: 90 Nissan 240SX Coupe 5.0
on4now4 wrote:hi everyone im fairly new here but i am looking at buying a 1991 240sx and the only thing that im worried about is the fact that it has a welded diff from what i have found it will cost alot to get a new diff installed and it would not be easy to do myself. so i am wondering if i drive it as an everyday car can having a welded diff break anything or cause any probs.
i wont drive in freeway. i drove my 240sx with welded diff for at least 8 months without problems.
its easy to swap diffs .. u only need some tools and a friend with smart brain and a little of time.
the first time was about an hour to swap diffs... so now i can do in 30 mins without help !!
u dont worry about the welded diff but u drive normal and dont step on gas while raining or similar.
on4now4
alright thanks man
on4now4
is having the welded diff going to destroy my tires really fast
rsdans240sx
Car: 1990 240sx KA
Faster, when you go around corners they opposite tire will chunk and kinda drag so yes they wont last as long.
1unar3clipse
Car: 93 240sx HB, 01 Dodge Dakota SLT
on4now4 wrote:is having the welded diff going to destroy my tires really fast
Yup
maik21
i am really sure its better than having a open diff.
an open diff will destroy ur tires faster if u drive hard and all the time only one tire will be damaged. to the oppossite side of welded diff, it destroy ur tires at the same time. i was very happy with my welded diff because tires last better than with open diff. when i switch to open diff my rear left tire wear very fast. at this time i change 2 times this tire and rear right tire seems to be very good.
