I too have a welded diff on my car.. it is great for drag and I do not mind it at all. The only thing I did not like was having to buy new tires for it every 2 months while I was using it as my daily driver. IF you don't have money to pay for a top end one I would recomend a j30, z32 or q45 swap. Right now my car is not a daily driver so I kept it that way, and for getting the car sideways would not change it for the worldshally2186 wrote:ive had welded diffs in my car and everything was fine..just sqeelin around turns when goin slow...other than that i was able to go sideways at all times...mine must not have been welded to good tho cause one of the welds broke and shot out of the case...but as for the money issue,if you have a buddy who can weld or if you can urself--its free---
another buddy of mine had a brand new VLSD..he drove around for a while to break it in, but it **** when he attempted his first burn out with it
Weak? I'm running a stock 1991 240sx canadian VLSD, pushing around 400+hp on it and so far so good, dropping the clutch at 7500 with 8.5 inch wide slicks, so this is probably why the hype is there...thenillaz wrote:I don't understand the hype of VLSD. It works almost like an open dif, its too weak. I don't know how much they run, but an s15 helical is about $400. Why waste you're money and time with a VLSD?
It was my dd for everything from track to everyday travel to work...I drove it about 75 miles every day, but at work I would say 30 of those miles would happen and it was not on a straight line, it was mostly turning every 2 to 3 blocks.rb25drag wrote:lyon23- Your buddy had to be drifting alot or doing alot of burnouts. The tires do not wear that fast. My buddy drives his daily to work 67miles 1 way, and don't have that problem.
cause helical diffs aren't made for drifting, vlsd will ock a lot smoother than a open diff and allow him to do jack. as a welded diff will allow you to kick the car sideways slot eaiser but tires chirp during turns and makes handling harder. Plus durability, I'd go with VLSD over welded from personal experience!thenillaz wrote:I don't understand the hype of VLSD. It works almost like an open dif, its too weak. I don't know how much they run, but an s15 helical is about $400. Why waste you're money and time with a VLSD?
