rsmithdrift »
https://forums.nicoclub.com/rsmithdrift-u36706.html
Tue Dec 28, 2010 10:52 pm
I had one for a short while. Had to go back to open and haven't been able to get another welded yet. Have known many people to have them. When I had one it was the ONLY mod to my car other than an intake and strut bars. I always run bald rear tires. I buy them when they're nearly bald and go do some drifting to break them in. They last 3 months tops, with an open diff. They lasted the same when I had the welded. That said I drift like a mofo open or welded so it makes sense. But if you're getting a welded it's for drifting so don't ever expect your tires to last long. lol.
As far as problems, they are scary as hell in the rain and the slicker it is outside the scarier it is. Basically if you turn in the rain, you are either drifting or going in a stright line straight off the road. So you HAVE to drift. Always. It's very predictable and easy but that said it's very easy to overdrive the car and make a mistake also. Brake and turn in the rain equals automatic traction loss. That's what's so damn scary when you don't intend to drift but it happens anyways and you push wide because of it and feel like your going off a cliff... no fun. So be carefull in slick conditions.
It's a great alternative. Mine broke because I slid off into the ditch and the twisting torque forces of the crash broke the welds in the diff and it eventually failed completely and siezed up. Which wasn't fun. I got a new diff from the junkyard and though I've always intended to get it welded I still never have 3 years later... oh well. I'm so used to the open diff I don't really need it and I always end up debating myself out of it. One thing I learned is that I needed more power cause it will make ALOT of forward traction even when drifting. So stock powered 240 is almost better off with an open diff cause you can keep the wheelspin up better. It'll def be welded when I eventually turbo it though.
So 1. only real problem is hard to drive safely in slick conditions when not drifting
2. yes. But I'd recomend learning how to make the open diff work for your advantage even more. (not everyone can though)
3. BE F'ING CAREFULL WHEN DRIVING NORMALLY IN THE RAIN AND ESPECIALLY SNOW/ICE
I would actually recomend a welded over a locker or helical or Vlsd any day. They all suck worse than an open diff for various reasons.
