WELD DIFF
Nissan dominates the drift scene - Always has, always will.
hkssupratt1994
Car: 92 240sx hatch
i just read people like the clutch type diffs and the kaaz 2 ways where can i buy these?and to weld your diff were do you weld at in the diff?
K-town240sx
Car: 1993 240sx
Are you asking about buying a aftermarket rear end or do you want to weld your diff? That or you are asking which one is better? You can't do both! lol I would honestly get a kaaz 2 way If I had the money but... If you want to do it cheap, go buy a J30 rearend. That or I would Buy a silvia rearend from japan. I may have read what your saying wrong...If you want a Kaaz 2 way at a cheap price I would honestly go to ebay.
adrianfromthecastle
Car: 1992 Nissan 240sx
hkssupratt1994 wrote:i just read people like the clutch type diffs and the kaaz 2 ways where can i buy these?and to weld your diff were do you weld at in the diff?
c'mon man... i know your a n00b, no offense, but are you new to the internet as well?
step 1: go on the address bar up top, its under the buttons that say "back," "forward," and "stop." this is where you enter your web address (i.e. nicoclub.com)
step 2: in the address bar, type in "yahoo.com" then press enter.
step 3: where it says search, on the right of it is a blank space where you can type in keywords, type in "kaaz 2 way." then press enter.
everything else will unfold in front of your keyboard
for the welded diff... this one is similar, but a little bit easier
up top, theres a search button (not where the address bar is, but in this actual website).
click on the search button, its the flashing red on that says SEARCH.
when it promps you to the next page, search "welded diff" or "weld diff." play around with the entered keywords until you find a good thread.
then read all the threads that are listed. that should give you a good amount of info.
hkssupratt1994
Car: 92 240sx hatch
i could do that buy a hear a weld diff is bad for a daily driver so i guess im going to go with the s15 rear end i hope it bolts right in,i'll see if i can find one on ebay
adrianfromthecastle
what are you planning on doing to you car, like event wise? j30 vlsd is a pretty common swap, and you can pick them up for cheap at the junk yards, but if your planning on drifting, it will only satisfy your habbit for awhile till you weld you diff or get a clutch type. if you wanna go the cheap route, just do a weld... its really not as bad as people say, just kinda noisy on turns... just becareful in the rain
neverlift
personally I will go weld being the cheapo I am. Trying to find a friend that has access to a tig and time that damn time .
hkssupratt1994
Car: 92 240sx hatch
yeah the tomei 2.0 ways LSD is 850 ,i found a 240sx weld diff for 170 just bolts right in put i hear of all the trouble if gives you as a daily driver should i save up for a 2.0 way?
hkssupratt1994
Car: 92 240sx hatch
i plain on drifting on the weekends and some events and i want it to not give me trouble as a daily driver,how bad are the welded diffs?
adrianfromthecastle
hkssupratt1994 wrote:yeah the tomei 2.0 ways LSD is 850 ,i found a 240sx weld diff for 170 just bolts right in put i hear of all the trouble if gives you as a daily driver should i save up for a 2.0 way?
imo.. you should save up, its well worth it. you're not drifting 24/7, and you'll save your tires as a daily driver. i'm saving for a 2 way as well... i cant afford to ruin daily driver tires.
hkssupratt1994
Car: 92 240sx hatch
same here do you have or had a weld diff before?what do they do beside ruin your tires does it jerk alot?
adrianfromthecastle
hkssupratt1994 wrote:same here do you have or had a weld diff before?what do they do beside ruin your tires does it jerk alot?
if theyre done right, no jerking or whatever. you'll see a lot of drag people with welded diffs. theyre pretty noisy in parking lots when you trying to park. other than that, theyre pretty fun, and they get the drift done.
hkssupratt1994
Car: 92 240sx hatch
so tires and a little noise is mostly all the negatives of a welded diff?
~4N~
My 240 has a welded diff, and it's also my daily driver. The noise and tire wear really aren't as bad as everyone makes them out to be.
hkssupratt1994
Car: 92 240sx hatch
really good thats what i was wanting to hear
beatlust
my s13 has welded dif and i think it contributes to the understeer.. i like the welded diff, my car isnt a daily though..
~4N~
beatlust wrote:my s13 has welded dif and i think it contributes to the understeer.. i like the welded diff, my car isnt a daily though..
You'll understeer if you turn too much. With the welded diff you have to get used to the fact that you don't have to turn as much to get sideways. I had to get used to it when going from an open diff to a welded one, but now I love it.
Biggamehit
Car: R33 Skyline
DR30 Skyline
Sil80
180sx
sadly my welded diff blew on me. i used an flux welder and the pentration sucked. only lasted for about 1 month. but why it lasted it was fun. one more paycheck and im picking up Kaaz 2way.
i had no issues in the rain with my diff. u lose traction only when u want to. understeering was a ***** at times at high rates of speed entering onramps lol.
~4N~
Some people's welded diffs fall apart the first time they drive it, but when they're done correctly, they will last pretty much forever. You just have to get it welded by someone reputable who has done it before.Have this guy do it:http://www.zilvia.net/f/showthread.php?t=103145
hayaimoto
Car: Sil80,full race EG6,Street DC2, Real deal RHD FEEDfd3s
keep in mind welded diffs are at 100% lock while clutch type lsd (kaaz,cusco,tomei,nismo,ats etc) are adjustable... i know alot of guys that have welded diffs and there holding up just fine, but cant adjust lock rate.
Return to “Nissan Drift Forum”
