Nfire247 »
https://forums.nicoclub.com/nfire247-u122910.html
Sun Feb 22, 2009 3:13 pm
I bought a 1990 240sx a few weeks back with a DOHC swap (assuming its an s13 DOHC because its got an external coil? tell me if i'm wrong). The guages didn't work when i bought it, even though it is a DOHC cluster. I assumed it was broken. I have replaced it with a known working cluster, and it still doesnt work, the 5 wires i have been told need to be run are run, and it is a DOHC harness. Engine runs fine for the most part. So i assumed something weird happened with the ecu, and went to swap it out with a friends DOHC edu. The car wouldn't idle at all and barely ran with me playing the throttle, BUT THE TACH WORKED.
Since then i have tried a known SOHC ecu, and my car runs just like it does with my ecu, which leads me to believe i am running a DOHC KA with a SOHC ecu. I thought this was impossible, but i am still new to 240's so im basically clueless. This is what my current and running ecu looks like...
The question i think I am asking now is Is there any way to run a DOHC KA using the SOHC ecu? like swap out some sensors or sumthing? my harness is pretty spliced up, and i think thats whats happening in my car.I've tested out two other known to work DOHC ecu's and my car won't run with either of them, i'd like to fix whatever some dummy did and get my car running w/ all DOHC pieces.Thanks
