the ECU coolant temp sensor 100% has an effect on your car not starting... i had a bad coolant temp sensor on my car and what would happen is the car would start but then just shut off.. whats happening is your ecu thinks the car is running SOOO cold or SOOO hot i think it defaults to cold tho but anyways when my car started the ecu was litterally flooding out the spark plugs with fuel trying to compensate for the "false temp" the sensor was sending it, so what i had to do was clean of the spark plugs wait a while for everything to dry re install them and the same thing happened i started the car it started right up but then shut off after idling badly... soo i replaced the coolant temp sensor off of a hunch and cleaned the spark plugs once more and car started first time with no problems since!ncturbospecv wrote:The sock on the filter is clean and the z32 filter is new as well. Is there any way the ecu coolant temp sensor could have any affect on this? I just replaced it and thats the only thing i even touched motor wise in awhile.
turbotank wrote:the ECU coolant temp sensor 100% has an effect on your car not starting... i had a bad coolant temp sensor on my car and what would happen is the car would start but then just shut off.. whats happening is your ecu thinks the car is running SOOO cold or SOOO hot i think it defaults to cold tho but anyways when my car started the ecu was litterally flooding out the spark plugs with fuel trying to compensate for the "false temp" the sensor was sending it, so what i had to do was clean of the spark plugs wait a while for everything to dry re install them and the same thing happened i started the car it started right up but then shut off after idling badly... soo i replaced the coolant temp sensor off of a hunch and cleaned the spark plugs once more and car started first time with no problems since!ncturbospecv wrote:The sock on the filter is clean and the z32 filter is new as well. Is there any way the ecu coolant temp sensor could have any affect on this? I just replaced it and thats the only thing i even touched motor wise in awhile.hope this helps man!
Tony
