verge513 »
https://forums.nicoclub.com/verge513-u90654.html
Tue Jan 10, 2012 10:26 am
ok this is the problem when i bought the car, the security/ interior fuse was pulled out.. i put it in and the side markers and rear running lights stay on..never turns off, with the fuse out nothing comes on until i turn the key then everything comes on. but shouldnt the running lights only come on when you turn the light switch to the running lights? and not be on all the time as long as the key is turned. even when i disconnect the light switch when i put the fuse in the running lights still come on...is this a alarm problem? i disconnected the alarm and no change.. 1990 300zx coupe na model...please help
