Postby
lbrowne »
https://forums.nicoclub.com/lbrowne-u3597.htmlTue Sep 09, 2003 6:46 am
A while ago I was on here asking about the stock washer fluid bottle with the built in pump on s13s.
The electrical connection leading into the pump itself was corroded away by road grime and fell apart when I had taken the fender off. Hence my windshield wash would not come on.
Well yesterday I noticed my wipers don't even come on any more either. I think this is coincedence..... think it could be the wiper motor itself?
Postby
llamabeta »
https://forums.nicoclub.com/llamabeta-u8998.htmlTue Sep 09, 2003 6:46 am
Possibly could be the motor. I'd be sure to check the fuse first. Due to an installtion (before I owned vehicle) with the fuses slots were spread out a bit because of a clip they put on the fuse to wire something else up. I added a bit of solder to one side to correct it. Check those fuses first.
Postby
Gmans13 »
https://forums.nicoclub.com/gmans13-u2486.htmlTue Sep 09, 2003 6:46 am
SO did you find the fuse or not? If so did replacing it do anything for you. I am having a similar problem where I totally removed the wiper fluid tank and don't work anymore.
