weird whriling noise? vid inside
dvd
http://www.youtube.com/w/?v=S0zqg_GYDZ8
i'm getting a wierd niose that i think is coming from the cams side. I'm thinking its the timing belt rubbing against the timing cover? Because when i put the timing belt, the belt wasnt completely over the cam gears. My friend told me that its ok because the timing belt will straighten back when i drive it. DO you guys think this is causing a problem? I guess the best way is to take it out.
Smurf6x6
Car: 93 CA18 Coupe
How much tension did you put on the belt? It's not sopposed to have to much tension or it's going to be noisy. (yah I didn't listen to your sound clip)
dvd
i thought the tensionor automaticly sets how tight??
jt15833
Car: 95' 240SX
it basically does but you swing it back and forth 3 times and let it do its thing then tighten it
NeedCAforS13
Car: CA swapped S13 coupe
dude don't run that motor anymore. your timing belt is binding against something and will break if you keep running it like that. I bet its already frayed and damaged... pull the cover off and check it out.
jt15833
Car: 95' 240SX
check if its evenly riding on the middle of the cam gears. if not, your probably missing the timing plate either infront or behind the crank sprocket
dvd
i pulled it off and it was sorta off of the cam gears( just like one of your posts on zilvia long ago JT hehe i searched.) I fixed it and now its not making that noise. I'm going to go check on it again though.
jt15833
Car: 95' 240SX
there should be a skinny plate, circle shape just a little bigger than crank spocket both in front and behind the crank sprocket to keep the belt aligned. the rear one is most likely there unless you removed the sprocket, but the front one is easy to lose. it can be seen in the fsm and ran me ~$4 from nissan.
dvd
man i dont know whats sup, i totally ****ed things up. The tensionor wouldnt even turn more than once! now the part where u put the hexagon key is stripped, i think i need to buy a new one =[ #@$@#?$@#
Yeah now the cover wont even go on. -=\
Modified by dvd at 2:17 PM 2/6/2006
