Cordeez »
https://forums.nicoclub.com/cordeez-u39770.html
Sun Jan 07, 2007 11:45 pm
Hey all, 1st time poster. anyway , on my SR, when i get out of VAC and into boost, the car seems like it is laborored and accelerates, but not as fast as it should be. (or so it seems) the revs do not seem to build as quickly when the car is under boost.
And when i begin to lift off the throttle, (throttle still depressed slightly, in VAC not boost) the revs begin to climb at a more accelerated rate then while in boost. My profec spec 2 says a good steady boost and my greddy gauge says a good steady boost too.
Mods.Redtop SRBadly slipping clutch (could this be the problem?) T28 Boost controller (7psi)exhaust from turbo backHKS SSQVwalbro 255
Modified by Cordeez at 1:56 AM 1/8/2007
