qship96 wrote:maybe all your keys were cut from the valet key?
Yeah ... this sounds like a possibility. Assuming that keys are not the original ones ...
But, I also like the valet position switch theory - my 2003 M45 also has the switch inside the glove box like my prior two Q45's did.
Do these keys open the car doors (not trunk) normally? How about the glove compartment - do these keys open/lock that? If that works, they are not valet keys.
One other possibility: maybe the teeth are a bit worn and are not engaging the trunk lock mechanism properly? Since keys are rarely used for trunks, it is possible that the mechanism there is not as worn as on the door.
Z
