silviamaniac »
https://forums.nicoclub.com/silviamaniac-u9235.html
Mon Sep 08, 2003 6:41 am
Hi there, this question is regarding my weird experience with my car.
My car has idle / stalling problem after replacing the timing chain. After the job is done (upper chain only, done myself) the car couldnt idle properly (sometimes) and timing is set exactly at 20.
To solve the problem, i cleaned up the throttle plate, MAF, IACV, got new o2 sensor, fuel pump, and AIV is removed.
I still havent go thru the EGR. but however, i had this weird problem where my safc will give me a TPS signal even if i do not step on my gas pedal. It is off by 1-5% sometimes.
Besides, my car has alot of "bob bob" sound coming out from the N1 catback, but just sometimes. Its weird because if it does that, the car will rattle with the same rhtym (a little) and i do suspect the cat is clogged. but sometimes it is totally OK.
The car ran smooth and no problem at all, no power lost no nothing, just refuse to idle and stall. Sometimes the engine is kinda like reving itself for no reason. and RPM is fluctuating.
I do not know why it happened all after the upper chain is changed. Btw, i m running a 6btm and blaster 2 coil.
Pls help me with this. Thanks
