I got 3mb wifi at my campgroundprogman wrote:yeah, get out of that camp ground and get to a wifi and upload those dyno results!
WTFcampground man wrote:Well they've not been able to solve the problems to even get this thing dyno'd...
TPS is reading some messed up stuff. They emailed this info to me.
With the wires physically removed from the ECU, the car still shows 3.6v...it should be 0.4 volts at throttle closed and 4.6v at WOT.
They said the TPS was fine, but believe it's an ECU problem. Have any of you guys had a similar problem? Input?
so are they fixing the said ''bug'' in futur CA18 nistune boards? cuz nistune is a big maybe for mecampground man wrote:Daughterboard has been repaired, but it was still is reading 3.6 volts on the TPS.
Matt from Nistune went through the software and ends up there was a bug in the program in which it was reading the coolant temperature sensor voltage as being that of the TPS.
That bug has probably been out there since Nistune was first created, but I'm probably the first guy to put Nistune on a N13 ca18de ECU, so the bug was never noticed until me.
Hopefully, this will solve the issue (I'll know by this evening), and the car can FINALLY get tuned and dyno'd.
I just hope I don't get charged some god awful high tuning bill because of this bug...
witht hat kind of service...im pretty sure ill be nistune pretty soon...just need a wide band.campground man wrote:It wasn't a bug in the Nistune board - it was a bug in the tuning software that comes with it.
It ONLY affected KN13 (Pulsar) ECU's, not other ca18 ECU's. It's already been fixed and an update posted on nistune's website.
I do have to applaud Matt at Nistune for fixing the bug and putting out the update the same day it was found.
