cracka400 »
https://forums.nicoclub.com/cracka400-u84217.html
Sat Jul 18, 2009 11:30 am
95% of the time I lurk these forums and learn everything I can from you guys, but I got a small issue I can't seem to figure out. I've searched almost every 240 TPS issue on the site and everyone seems to have a little different problem. Ok, so here is mine. Back probing the middle wire on the TPS shows that I have 0.45 volts constant when I have the key in the ignition and motor off. Throttle closed shows that I am hitting 2.00 ohms. Now with throttle wide open I am peaking at 8.99 sometimes 9.12 ohms and no higher. Could this be that the sensor is shot or is getting bad? Any help is greatly appreciated.
