BlueTyGator »
https://forums.nicoclub.com/bluetygator-u39857.html
Sat Jul 14, 2007 7:33 pm
I have a 92 240sx KA24DE 5spd Stock.
Been having trouble with my idle. Tested my Tps today. The results I got were exactly the oppisite of normal. If someone could look over this and tell me if I'm doing this right, and what to do about it,, I would really appreciate it.
The article in the FAQ states -----------------------------------------------------------------------------------------------------------"With the locking tab pointing UP, the terminals are A, B, and C, from left to right. Make sure that resistance between terminal A and B of the connector half (female) that goes to the TPS changes when opening the Throttle Valve manually.
The results of the test should be:
Accelerator Pedal Condition Resistance in k Ohms
Completely released Approx. 2Partially released 2 -10Completely depressed Approx. 10If test shows "No Good", replace Throttle Sensor. "---------------------------------------------------------------------------------------------------My test show
* 10 released * 2.5 fully depressed
I couldn't figure out why it would be backwards. Just to be thorough, I tested the ohms between the B and C as well.
* 2 released* 9.5 fully depressed.
Is it possible my TPS is installed backwards?
Looking at the page in the FSM it would appear that I have it correct.
__________________________________________________________________________________________________________________________________________________________________________________
I also have a question about adjusting the Tps for idle.
According to the FAQ-----------------------------------------------------------------------------------------------------------VOLTAGE ADJUSTMENT:
1. Loosen the 2- bolts that hold the TPS.2. Start engine and warm up sufficiently.3. Measure output voltage of Throttle Sensor using voltmeter.4. Adjust by rotating Throttle Sensor body so that the output voltage is 0.45 - 0.55 volts.5. Tighten mounting bolts.6. Disconnect Throttle Sensor harness for a few seconds and then reconnect it.
Note: With the locking tab of the connector pointing up and looking at the back of the female connector as the wires go into it, terminal #1 is the one on the LEFT. #2 is in the MIDDLE and #3 is on the RIGHT.
Output voltage is measured across terminals #2 and #3 from the harness side of the connector."-----------------------------------------------------------------------------------------------------------
I know I'm going to sound like an idiot for asking this,
If I have to disconnect the Tps harness to measure the Voltage.... How can there be any voltage coming from it? I get power (5V) coming from the ECU side of the harness. And it has good ground. But I just don't understand how I am supposed to measure the voltage of the TPS without disconnecting it first??? With out power going to it theres just no way for power to come out right... So whats to measure
If someone could point me in the right direction here that would be great.
