oh and sorry i just noticed you swapped your mafGO240 wrote:I think we have the same problem tomorrow i'm swapping my mass airflow sensor because one of my friends said that was his problem i'll let you know and like cool said if its your ecu i can test that as well since i've got one more laying around we shall figure this out
looks like your gona need to change that pesky sensor in the dizzy man..that can be your issue...but before ya go there..test the injectors..just in case..you need an OHM electrical tester of some type...nissan for many years used high empeedence injectors..so if it says 17-19 ohm when you test them..then there good...if you get 15-3 your screwed and need new ones...now that sensor for the cam position is incorporated into the dizzy on some modles....that means you might have to get the whole dizzy to fix it...if your lucky..you can ebay a working one for under 100 bucks..good luck.240Kahn! wrote:Did that too. Got a MAF code, an O2 sensor, and at one point a Camshaft position sensor code. Eventually got 55 after I replaced the first two aforementioned parts, so I guess that rules out the MAF still being bad
