Weird?
surfer240sx
Car: 90 240sx sr20det
My friend has a 255 and 8-1 fmu setup on his ka-t. he has ran 10 lbs on his t3 63 ar not sure the exact specs on it as it was used... his aem uego is showing 11.6 at wot but at idle its completely lean doesnt even read afrs, any ideas y this is? o and more importanly how the hell is he getting these afrs on that size turbo with the stock 259cc injectors? yes i said it stockers at 10 lbs on t3
neverlift
I do it all the time.... , even go to 11~12psi with it, but I'm squirting water. However my disc is a 7:1 and base fuel pressure is 35ish. Its not 'the safest' plan of action and I dont go telling people to do it. But as I stated in the fmu recal thread some people will/want/need to flex the rules.
I'm wanting to hit 15psi off a tiny turbo with nothing more than timing retard/walbro/fmu/water injection. Its a small t3. A local guy made 320 something at 12psi on walbro/fmu. I dont think he even retarded timing(really not safe over 8psi).
surfer240sx
he has a cometic head gasket and thinks his timing needs to be set at 22 * his turbo is big i thought it is only safe to run that kind of boost on a t25 and your not even supposed to run stock injectors on anything bigger let alone 10psi but its working! im going to make sure his afrs are ok im gonna ride with him tonite also gonna try to figure out wat kinda turbo beast he has in there
WDRacing
10 psi compressed charge air from a T25 is going to be hotter then 10psi charge air from a T3 or T4 compressor.
The size of the turbo doesn't start to make a difference in flow/volume of air until you're running more then 12 psi. Bigger compressors move more air, but generally the differences in volume are minor in the lower boost levels.
The FMU isn't causing a lean condition.
