Ceptos »
https://forums.nicoclub.com/ceptos-u840.html
Wed Sep 22, 2004 5:18 pm
is there anything else you notice the car doing while your just driving or cornering? i had uneven tension rod bushings before, i felt the wobbling sensation under braking, but also got some vibration at highway speeds. and i noticed a rubber noise when going over some speed bumps. these are easy to check, you cant miss the huge circular bushing, if it looks dry rotted or cracked or has rust on it or the tension rod (from the liquid escaping) then it is worn.
an excellent and cheap upgrade would be a set of spl tension rods. and you can install them yourself, tho access to a torque wrench is necessary.
when you say sway, do you mean steer side to side, or actually swaying like in a corner?
Modified by Ceptos at 11:32 PM 9/22/2004
