Weird Starting Problem (S13 SR)
sr20detRcr1
Car: 92 Nissan 240SX
I get into the car, let the fuel pump prime until it stops. Crank it and it just cranks and will not turn over, so i back the key out and let the fuel pump prime a 2nd time. Once its primed the 2nd time i crank it and it starts.
it used to run fine, the only things i changed were a new body harness,took off the valve cover to paint it, and pulled the turbo and manifold off and now this happens
and the car runs fine when driving, just starting it has trouble
im baffled on what could be causing this
sr20detRcr1
help?
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
either fuel pump (most likely) or FPRwould be my guess
