weird starter issue
jinjinweiwei
Car: 95 240SX
yesterday I drove my car to art class, and after the class I got into my car starting it, but it just clicks. I was thinking okay... starter selenoid might stuck again, so I taped it a lil, and tried again. "Click" so I tried couple more times it still just clicks, then nothing... nothing... not even a click... so I called my friend that my starter went bad and car is not starting asking to get a ride. after the call I went back into the car and it still clicks and clicks. I was messing around with gears (mine is an auto, but I was just trying everything) so I put it in neutral and pressing my brake and tried to start the car "vrrrooom" it started....
I just tried to start it again, nothing weird happened it just start right away...
I need to know what caused that? the starter went bad again? or the relay? Thanks for the help.
janda240sx
Car: 1995 240sx se
The second time you started it. Was it in nuetral or park? My fiances done this same thing. I swapped the shifter and no more probs. (I just had one laying around.)
jinjinweiwei
Car: 95 240SX
the car was in neutral when it started.
is there anything else could cause this? experts I need your insights and knowledge!thanks!
Modified by jinjinweiwei at 3:14 PM 5/11/2008
janda240sx
Car: 1995 240sx se
Try putting it in park again and see what happens, you might just need another shifter.
jinjinweiwei
Car: 95 240SX
I tried couple times today, no problem starting it.... my car is being like a prego women!!! so dramatic and unpredictable!!!
